Front end loader problem
   / Front end loader problem #1
keevan
Fort Bragg CA
Kubota B2910, L3901
I have a Kubota 2910 tractor with backhoe and loader. The front end loader bucket will go up but won't come down unless I rotate the bucket up and down back and forth (slightly if I have anything in the bucket) . The valve is made by Husco and is a 9210-B2A0. I can't seem to get any info from them. Any ideas?
   / Front end loader problem #2
Im sure others will have the problem solved and know the first thing they will say is the quick disconnects might have popped off.
   / Front end loader problem #3
It sounds to me like the spring detent on the valve is worn out. I have a problem with mine also. I have disassembled it. I am currently trying to find the repair kit at an affordable price.
The detent assembly is at the lower front end of the valve body. You can access it by removing the hardware at both ends of the valve body and sliding the valve out through the bottom.
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2014 MACK GU713 WINCH TRUCK (A53843)
2014 MACK GU713...
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
2014 VOLVO EC220 DL EXCAVATOR (A51406)
2014 VOLVO EC220...
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
