Front end Loader No Down Presure
   / Front end Loader No Down Presure #1
JackMentink
Rolla, Missouri
2008 Montana R3644
I have a Koyker 160 FEL on a DF254b chinese tractor. Its about 3 years ond. The front end loader Has no Down pressure and will only drop by gravity. Everything else seems to work fine. Any body have any thoughts what is wrong? It has a single joystick style operator that controls all operations
   / Front end Loader No Down Presure #2
If Everything else seems to work fine....... then it sounds like to me the joy stick valve is not diverting the fluid to the cylinders to lower,.. if the color bands are still on the hoses there should be pressure on the red one out of the valve when holding the joy stick to lower. Hooking a gauge up helps to trouble shoot.
There should be an ID picture page in your owners manual. If you dont have one ... contact me through my web site with a fax number.
www.ranchhandsupply.com
Ronald
Ranch Hand Supply
   / Front end Loader No Down Presure #3
Well it sounds like one of the arm cylinders is leaking by and needs to be rebuilt,we had a loader do the same thing and one of the pistons came off inside the cylinder.You can also try switching the hoses that curl the bucket to see if it;s possibly in the valve,if you switch them and it works it's the valve,if not the cylinder.I keep some Koyker rebuild kits in stock,we just need the cylinder size,1-3/4"or 2"
Tommy
Affordable Tractor Sales
Just to let everyone Know in working with the tractor and FEL a little more and after e-mailing Koyker, (and them calling me back promtly and being very helpful) I have discivered that this Koyker loader has a down pressure mode if you push the joystick partially forward and a free float if you push it all the way forward (gravity).
The koyker rep informed me of this and that is the case. So if you have one just dont push it all the way forward and you will have down pressure.
   / Front end Loader No Down Presure #5
My Koyker 195 fel works exactly the same way. I Didn't think to ask if you were doing that... (pushing into float position).
   / Front end Loader No Down Presure #6
Thanks for the information. I thought something was wrong with mine also.
2020 Nissan NV200 Cargo Van (A51692)
2020 Nissan NV200...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2005 Freightliner M2 106 Dumpster Carrier Truck (A51692)
2005 Freightliner...
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
FAKE (A52472)
FAKE (A52472)
