Front End Loader Joystick only clicks under pressure will not lift tires of ground
   / Front End Loader Joystick only clicks under pressure will not lift tires of ground #1
mzmama516
Oklahoma
Branson 3520r
Our front end loader on our Branson 3520r will not lift the front tires off the ground anymore. It still carries weight, raises up and down, dumps etc. Any ideas on the problem? Thanks
   / Front End Loader Joystick only clicks under pressure will not lift tires of ground #2
Check your relief pressure.
Weak cyl seals.
Are you trying to raise the front wheels using tilt and regen? If so, use about half lever.
2016 BOBCAT S850 SKID STEER (A52705)
2016 BOBCAT S850...
1674 (A54756)
1674 (A54756)
20ft. Deer Gate (A53424)
20ft. Deer Gate...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A54757)
UNUSED RAYTREE...
UNUSED IRANCH EXCAVATOR ATTACHMENT SET (A54757)
UNUSED IRANCH...
John Deere BD1108 (A50123)
John Deere BD1108...
