Jrasband
Platinum Member
- Joined
- Dec 31, 2021
- Messages
- 543
- Location
- Southwest VA
- Tractor
- Kubota M7060, Case IH 585 4wd, BCS 853, Kymron ZX22
Tractor is LS XG3032
My front end loader curl cylinders are not working like there suppose to. They work some but are struggling to curl at all positions when the loader is at various heights. The curl cylinders going down seem to work best when I have the joystick in the down and right position at the same time. They do not work at all when the loader is all the way up. Though I can see the lines move with pressure at all times when I move the joystick.
These are symptoms of the loader with out any load other than a empty heavy skid steer bucket. I noticed with the light weight forks that the curl cylinders seemed harder to operate going down. Meaning the heavy protruding weight of the skid steer bucket helped pull out the cylinder rods is my take.
The lift cylinders seem to be working just fine.
I am not low on hydraulic fluid, There is no pickup screen. I have not yet changed the hydraulic filter. All other hydraulic functions on the tractor are working fine.
