Front End Loader Arms and Bucket Cylinders Barely Moving
   / Front End Loader Arms and Bucket Cylinders Barely Moving #1
spindlewood
Bronze Member
Northern Idaho
Kioti DK40SE HST Cab
I just took off my front end snow blower from my DK40 and am attempting to hook up my front end loader. I've been doing this for about 9 years, and I've never had an issue.
I've:
  • moved the tractor in place so the arms are aligned
  • hooked up (twice) the 4 hoses and they are color coded matched
  • Given power to the 4 directions/ hoses with only slight cylinder movement.
  • Checked the transmission fluid level and it registers on the dipstick.
There's not enough power to tilt the bucket (left/right) or extend/contract the arms (forward/back). They move a small amount, but that's it. I've checked the other control arms in the cab to make sure they are in neutral position.
The Front End Loader spent all winter outside as it always does - covered with tarps (not ideal, I know). Is there any way for rust to possibly be an issue?
Any ideas what to try? I'm stumped.
   / Front End Loader Arms and Bucket Cylinders Barely Moving #2
My first thought is that have two hoses crossed even if they are color coded. Can you physically trace the hoses from the lift cylinders to verify that both ends are connected to the same spool? These can be labeled A1, B1 or something similar.
Very unlikely anything wrong with cylinders.
   / Front End Loader Arms and Bucket Cylinders Barely Moving #3
Do you have any rear remotes? One may be "on", creating some dead heading. Just a thought....
   / Front End Loader Arms and Bucket Cylinders Barely Moving #4
Especially if he was feeding the snow blower from the remotes?
You were 100% correct. Not sure if this is age related, color blindness, or a case of changes I made when swapping to the blower last fall. I need to label better is the final assessment. I solved it by getting out the manual and tracing the lines. Sure enough, it showed me which two were swapped
I do run the blower from the short handles by my right knee (I didn't know these were called remotes). I made sure these were off. Good thoughts, though. Thanks.
   / Front End Loader Arms and Bucket Cylinders Barely Moving #6
Spindle,
Thanks letting us know what the problem was. And I can relate to age, color blind. I remember as a kid people saying with age comes wisdom, sure wish the wisdom would show up soon…
   / Front End Loader Arms and Bucket Cylinders Barely Moving #7
Spindle,
Yep, for some of us wisdom was late out of the gate...
2010 Ford Taurus Sedan (A50324)
2010 Ford Taurus...
2001 TOYOTA 7FCGU25 FORKLIFT (A51222)
2001 TOYOTA...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
2013 FREIGHTLINER CASCADIA DAY CAB (A51219)
2013 FREIGHTLINER...
KUBOTA M6800 TRACTOR (A51243)
KUBOTA M6800...
Woods 3180 Batwing Mower (A50514)
Woods 3180 Batwing...
