Front End Attachment Options
/ Front End Attachment Options #1
OHMontys
I was told recently that the hydraulics on the front end of CUTs are not "fast" (hyd. pump flow rate) enough to operate attachments that a typical Bobcat/Skid Steer would run. The reason I ask is that a friend suggested that I get the 3rd function hydraulics option so that I can rent these attachments and use them on my soon to come CUT. Thoughts?
Thanks...Steve
/ Front End Attachment Options #2
Welcome to TBN:D
That info is correct. most CUT's have a flow rate of 5-10 GPM, and SSL's use a lot more flow, plus they are often to heavy to be useful on a CUT.
The 3rd function is useful for light duty grapples and 4n1 buckets.
/ Front End Attachment Options #3
So, this is correct. CUT's across the brands range 5-10GPM.
Most skidsteers run 25+GPM. Some, run 30+GPM "High-Flow". My buddies Bobcat S185 is 16.9gpm standard, 26.4 high-flow. Some of the smaller Bobcats are 13-14 gpm.
To run a hydraulic implement, you would need to add an auxillary system, ie PTO hydrualic pump, remote tank ect. It would be kinda like the 3pt backhoes that use a PTO pump for hydraulics.
You have to be careful too; some of the SS/CTL implements are heavy too...
Thanks...Steve
/ Front End Attachment Options #4
A CUT would be OK for non-powered hyd. implements (or what do you call them)...Example: 4-in-1 bucket, grapple, etc...You can't run implements that have a hyd. motor powering them...Example: snowblower, chipper, broom, tiller...etc...There are also smaller 3rd function implements designed for CUT's...
2020 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2020 CATERPILLAR...
2013 FREIGHTLINER CASCADIA (A65643)
2013 FREIGHTLINER...
2018 INTERNATIONAL HX620 (A65643)
2018 INTERNATIONAL...
2018 DODGE RAM 5500 FLAT BED TRUCK (A65643)
2018 DODGE RAM...
2002 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2002 Ford F-250...
Stout Brush Grapple XHD84-6 (A66285)
Stout Brush...
