Front driveline seal on 110TLB.
   / Front driveline seal on 110TLB. #1
AKfish
Super Member
Alaska
JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
My 110 is fast approaching 1,000hrs. on the meter. It's never been in the shop for repairs. Many will know that the only complaint I've had about my 110 has been a "chirp" in the steering pump. It still does that... but it's never failed!
Nonetheless, I've noticed a small hyd leak near the front differential "pumpkin". I thought maybe the steering cylinder hoses were rubbed through or maybe the seal on the front differential was beginning to leak. Well, after some investigation - I found the culprit.
It's the seal at the transmission housing where the front driveline stubs out and connects to the front driveshaft. The hyd oil is dripping down into the inside of the plastic shield and coming out onto the rear of the front differential and the steering cylinder.
After looking at the technical manual and JDParts for both the 110 and the 4610 CUT; the repair doesn't appear that difficult. Remove the shield, drive out the split roll pins on the driveline and pull and replace the seal - and maybe the bearing and split ring.
Am I correct? Appreciate any ideas and/or clarifications.
AKfish
   / Front driveline seal on 110TLB. #2
I have a new 110 with 50 hours on it and I noticed a small amount of hydrolic fluid in the same locaton. Not enough to drip on the ground. I am watching it and will check to see if itcoming from the same location as yours. Also have the power steering chirp and tug. I plan to complile a listand take it to the dealer in the spring while its under warranty
Welcome to TBN, wamsutta. The JD110 is a great tractor! As I indicated, the problems I've encountered are pretty minor - but, aggravating!
Very good idea to let your dealer know as soon as possible. Once, you've established a history of the issue - your dealer will be in better position to help you when the repairs are finally needed - and insure that the repair is covered under warranty.
Good luck.
AKfish
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
2005 CATERPILLAR 740 - 6X6 OFF ROAD WATER TRUCK (A52706)
2005 CATERPILLAR...
2013 Jeep Patriot Sport 4WD SUV (A53424)
2013 Jeep Patriot...
2007 Ford F-750 Chipper Truck (A52377)
2007 Ford F-750...
2012 VOLVO EC300DL EXCAVATOR (A51406)
2012 VOLVO EC300DL...
VERMEER NAVIGATOR S3 D10X15111 DRILL (A51406)
VERMEER NAVIGATOR...
