Front drive shaft noise
   / Front drive shaft noise #1
B2400
Platinum Member
Western Illinois
2016 B2650 ROPS, 1998 B2400 (sold!)
Has anyone had trouble with their front drive shaft? Mine recently started making a scraping noise, but it doesn't sound like a u-joint is out. Drive shaft has a lot of play, radially, up near the transmission but due to the tight confines of the area I can't inspect it for damage other than grabbing the shaft in the middle and moving it around. The sound is most noticeable in reverse and also goes away when I engage fwd. It appears as though you might have to split the trans away from frame to access this for repairs and I'm really not up for that headache. Any ideas out there??!! /forums/images/graemlins/confused.gif
Mike
   / Front drive shaft noise #2
If it makes noise in one direction, but not the other, that would indicate that there is a dry universal joint. See if you can get to the fitting to put some lube into it. Many times this will resolve the problem for good......
Permanantly lubed joints unfortunately. Top joint is inaccessible and I fear thats the one that is causing trouble
Update: Apparently it was just the plastic cover rubbing at the bottom u-joint. This has happened a couple of times but for some reason the noise was different this time. Still concerned about the amount of "wobble" in the shaft and would appreciate any advice on this.
   / Front drive shaft noise #5
You can replace the end yoke to tighten it up a bit. Make sure you grease the splines before installing it.
2022 SIDUMP'R 48FT TRI AXLE SIDE DUMP TRAILER (A54607)
2022 SIDUMP'R 48FT...
LINDE WELDER (A53843)
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
TRANSMISSION JACK (A53843)
TRANSMISSION JACK...
DOOSAN G25 GENERATOR (A53843)
DOOSAN G25...
Miles read : 112,969 (A50323)
Miles read ...
