front drive line falls out of u-joint
   / front drive line falls out of u-joint #1
spinyata
Just bought my first tractor.Used 05 Kubota BX2230 with FEL. It was missing the u-joint between the two drive lines for the front wheel drive. I installed a factory u-joint today and the drive worked fine until some rough terrain allowed the front axle to move far enough to allow the drive shaft to slide out of the u-joint. It seems that there's only about .5 inches of contact between the u-joint and the drive line while on level ground. Does this sound like enough? Any ideas?
Thanks. Jerry
   / front drive line falls out of u-joint #2
Check for a pin holding the u-joint and drive line together? It may be missing.:confused:
You may have to extend your drive shaft so it does not fall out. :)
The pin is in the lower u-joint. The upper end of the drive shaft has the longer splines (for some play) but it does also have a spot for a pin. The manual shows a pin only in the lower joint. Should I pin the upper joint?
   / front drive line falls out of u-joint #4
If that drive line moves it can't be pined on both sides. Picture would help.:confused::ashamed::confused2:
2024 New Holland T8.410 MFWD Tractor (A52748)
2024 New Holland...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
2 JATCO CORP Transmissions (A50325)
2 JATCO CORP...
PORTABLE INDUCTION HEATER (A52472)
PORTABLE INDUCTION...
2007 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52577)
2007 PETERBILT 387...
