Front Drive Kit
   / Front Drive Kit #1
rodfreda
Gravely made a front drive / PTO kit for 4 wheel tractors.
This allows you to use any walk behind attachment with the 4-wheel Gravely Tractor.
Does anyone know if the kit is the same for all models (400,8000, G16, G20).
I found an unit (400 series) being sold for parts with the front end kit.
Will the kit work on a 16G or 20G?
Rod
   / Front Drive Kit #2
The front-drive kit is primarily for running front-mounted attachments like the 38/40/44" snowblowers and the 48" sweeper. There is additional hardware that can allow you to run the 2-wheel attachments also.
My father has the entire setup on a 20G.
   / Front Drive Kit #3
the frame is longer on the G series so the driveshaft will be a little short as well as the hydraulic lift rod.
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2015 FREIGHTLINER...
SCAN TO RECEIVE TEXT UPDATES (A52705)
SCAN TO RECEIVE...
2012 Cadilac SRX SUV (A53424)
2012 Cadilac SRX...
2001 John Deere M665 (A50120)
2001 John Deere...
Estate Equipment Auction 9/27/2025
Estate Equipment...
2020 BOBCAT T870 SKID STEER (A52705)
2020 BOBCAT T870...
