front chains on 2410?
   / front chains on 2410? #1
winchman
Bronze Member
western, pa
kubota 2410 with loaded R4s
I would like to put chains on the front of my 2410 (R4s) but am concerned about the clearance around the steering knuckle (where the tie-rod end is attached). Anyone running chains on the front of their 2410? I read that PKS has them on his B2400, but does it have the same clearance as the 2410?
Thanks,
winchman
Can anyone help me out here?
   / front chains on 2410? #3
There should be no physical difference between the B2400 and the B2410 in the aera you mention. The differences lie in cosmetics, the 3-pnt, improved hydro output etc but the steering arm and knuckle area you mention are the same I am pretty sure. Kubmechanic ought to know for sure maybe?
J
   / front chains on 2410? #4
As an aside, the best place to ask this question or any Kubota related question for a good response will be in the Kubota section and not the general topics area. Many people I bet only read the sections related to their tractor brand. That is what I think anyway, I could be wrong. Good luck winchingman.
J
2008 Nautica International RIB 24ft Cat Boat (A50324)
2008 Nautica...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2017 FREIGHTLINER...
DIRTDOG CBX60 5' BOX BLADE (A51243)
DIRTDOG CBX60 5'...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
J & M 1150 Grain Cart (A50514)
J & M 1150 Grain...
SET OF HANG ON WHEEL LOADER FORKS (A51242)
SET OF HANG ON...
