front bucket dropping in minutes
   / front bucket dropping in minutes #1
intheground
jinma 284
Hi guys new to this site. I have a jima 284 with a hydraulic problem that has got me talking to myself. When I put the bucket in the up position within 5 minutes the bucket is down. There are no signs of leaks all fittings are tight. I changed the hoses around from lift to curl and when I did that the lift was fine in the curl fittings in the valve. (so I think the valve is working) I loosened the fittings one at a time worked the hydraulics to try to get out any air but still no change. I also put the bucket down so it lifted the tractor a few inches and it held fine. the cylinders look good no leaks or scracthes. all the rest of the hydraulics work fine. Any suggestions? thanks
   / front bucket dropping in minutes #2
It sounds like you may have an internal leak in your joystick valve. Putting the bucket down and lifting the tractor uses different valving ports inside the valve than those needed to hold the bucket in the up position. The internal port check valve most likely has some dirt, a speck of rust, or an deteriorated O-ring seal preventing it from seating properly. If you are unsure how to take it apart to check and clean I'd recommend taking it to a tractor dealer or hydraulic shop to have them check it for you. It could also be inside the lift cylinder ram seals. I had a similar problem with my tractor that was less than a year old but it only dropped about an inch an hour, not as fast as yours. Mine was an internal leak in the joystick valve which was replaced by the dealer under warranty.
   / front bucket dropping in minutes #3
If you have a double acting cyl with rod ends connected to tank (single acting), it can be cylinder piston seal...Disconnect rod end and lift till you get relief valve opening...if is oil coming out...piston seal bad..... (I have seen valves with special spool connecting rod end to tank aswell),
If you have true single acting cylinders it must be valve internal leak...
when I switched ports with the lift and bucket and the lift held fine in the up position wouldn't that indicate that the valve is working?
   / front bucket dropping in minutes #5
By switched ports do you mean that you hooked the raise up to the dump ports. If you did and it held up fine it indicates that your cylinders are fine and the lift valve is what is faulty
when I say I switched ports I mean I took the 2 hoses for the bucket and placed them in the ports for raise and lower and took the raise and lower hoses and put them in the rollback and dump ports so raise and lower became rollback and dump and rollback and dump became raise and lower. so whichever of the 2 ports the bucket was connected to it still dropped in the up position and the raise and lower of the boom worked fine in either position.
   / front bucket dropping in minutes #7
well if the bucket still dropped when raised no matter which ports it was hooked to I'd say the seals in the cylinders are shot. The only other possible cause is that you have two faulty valves which is unlikely
   / front bucket dropping in minutes #8
if you have a true double acting cylinder, the oil volume for the piston rod have to leak out when bucket go down......that will be out thru the valve....then both piston seal and valve are leaking....lift bucket to top, all extracted cylinder, disconnect the rod side, plug port on valve, keep try to lift.....relief will open.....IS OIL COMING OUT OF THE ROD SIDE HOSE????????????.....
if so piston seal is bad....
thanks akkamaan, will have to go find a couple of plugs and try your test. Just another question (unrelated) if you hold the bucket in the full up postion will the prv open and release oil? as you can tell not to familiar with hydraulics.
   / front bucket dropping in minutes #10
This may or may not apply to this case, but, I do know that many Jinma dealers replaced the "double lever" Chinese loader valves with better joystick valves before even selling the tractor for the first time. The Chinese loader valves are noted for problems ----------
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
2013 New Holland BR7060 (A50123)
2013 New Holland...
CHAMPION 1 PERSON GAS EARTH AUGER (A51248)
CHAMPION 1 PERSON...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
2012 Bomag BC572 Refuse Compactor (A51691)
2012 Bomag BC572...
8' DISC HARROW (A51247)
8' DISC HARROW...
