Front Brush cutter for sub compact JD1025R
   / Front Brush cutter for sub compact JD1025R #1
jbmike7
Lugoff,SC
2014 JD1025r
I have a JD 1025r FELB and 15 acres and I have been cutting down trees and pullin out stumps and making a road around my property so I can someday put up a fence around the property. I would like to adapt a Brush Hog to the FEL to make brush removal easier to view. Even though I realize a lot of people are thinking that why did I get a sub compact tractor with 24hp I tell you that this tractor works good for me and its what I could afford at the time.
Any how I hope someone could give me some ideas about adapting a Brush cutter to the FEL. Thanks in advance
I would like to start over by introducing myself like I was suppose to. My name is Michael J Kantz and I am retired from the Army with 23 years and just purchased a JD 1025r so when I retire again in 3 years I will be able to get the work done on my property as stated above. Looking forward to reading the valuable info your members have.
   / Front Brush cutter for sub compact JD1025R #2
You will probably need to power it hydraulically, which will require a PTO power pack. Those are very expensive. I just don't see being able to do it practically.
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2015 INTERNATIONAL 4300 26 FT NON CDL BOX TRUCK (A51219)
2015 INTERNATIONAL...
2013 Ford F-150 (A50397)
2013 Ford F-150...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A49461)
2022 Ford F-250 XL...
2014 JOHN DEERE GENERATOR SET (A51222)
2014 JOHN DEERE...
