Front broom for 4310
   / Front broom for 4310 #1
johnno
Bronze Member
NW CT
Will the JD broom fit the 4310? I have the mid mt pto. Also, what is a good estimate of the $$$? Think it will work real well for spring clean up
   / Front broom for 4310 #2
I have the old #26 broom. I had it for my 4400 and it also fits the 3720 just fine. If you have the mid PTO, then you need to get the front (long) PTO shaft , the front quick attach hitch (with hydraulic lift and angle and the PTO carrier bearing) and then the broom itself. There was one in the classifieds here for around $1800 I think. I got mine used locally from a raceway. I paid $2200 for it complete.
If buying new, you need
1) the broom (60" broom)
2) BM19804 Mounting Frame with Drive Shaft and Hydraulic Angling
3) LVB25306 Front Quick-Hitch and Hydraulic Lift
Cost about $4600.
I had an interference problem with the mid mower lift bracket on the 4400. I had to mill about 1/2" off of the brackets. But the 3720 cleared it just fine with no mods. Deere must have found the problem and corrected it. Hopefully your 4310 has the corrected lift brackets (if you have the mower). If you already have a snow blower, then you already have the long PTO shaft and the front quick attach hitch. You would just need the broom.
Chris
2024 JOHN DEERE 8RX310 LOT NUMBER 77 (A53084)
2024 JOHN DEERE...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
2025 New/Unused Wolverine 48in Skid Steer Trencher (A51573)
2025 New/Unused...
2008 KALMER 4X2 SPOTTER TRUCK (A51247)
2008 KALMER 4X2...
New Wolverine Skid Steer Hydraulic Breaker (A53002)
New Wolverine Skid...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A51573)
New/Unused AGT...
