front boot
/ front boot #1
slammer3364
Bronze Member
Jinma 284
need to replace front boot on my jinma 284 looks like you take cotter pin out of bolt, take bolt off. that tie rod or steering should drop or tap out correct.slip boot on and replace
/ front boot #2
It likely wont be quite that easy. Tie rod ends are taper locked in place and some can be a bit stubborn to get loose. Without having a "pickle fork" to pry it loose, sometime they will come loose by placing a sledge hammer on one side for back up and then sharply rapping the opposite side with a 4# shop hammer. This works about 90% of the time.
/ front boot #4
Or in the case of the Jinma 284, if you retract the boot you will find that the tie-rod end is screwed onto the hydraulic cylinder rod. You can crack the locknut but leave it in place and unscrew the rod out of the rod end(it has a wrench flat) This is a good thing to check from time to time anyway as they can come loose. the first indicator is that you will not be able to turn as far to the right as to the left
As for a boot a rancho suspension silicone rubber shock boot is a perfect fit for the 284 steering cylinder. My original boot disentigrated/tore a year or two after I got the tractor(12 years ago) and I put on a red rancho boot and it has been there ever since...
2020 MACK P164T (A60736)
2020 MACK P164T...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
(1) Blackstone-OTR 39x15-22.5 Foam Filled Tire w/ Rim (A60463)
(1) Blackstone-OTR...
Bobcat 72" Bucket (A60463)
Bobcat 72" Bucket...
