Front Blades on 4100
   / Front Blades on 4100 #1
TxBillyed
Bronze Member
Midlothian, Texas
John Deere-4100
I am looking at a 54In front blade for my 4100. The dealer quoted a great price however he did not have all the information on tilt angle and hook up. Does anyone have one and can give me some more information. The dealer talked about an additional kit for $450 buck for the hydraulically controled balde?/w3tcompact/icons/hmm.gif
Bill
   / Front Blades on 4100 #2
Bill,
I have the JD 54 inch front blade. What do you need to know? I have plowed with it the past 3 winters. I have no complaints other than to wish it was a foot wider.
John
   / Front Blades on 4100 #3
total cost for the 54" blade with the Quik-Tatch hitch and angle runs between $800 & $900 complete.
   / Front Blades on 4100 #4
John,
I have been debating getting the 54" plow for my 4100 HST, instead of an FEL for reasons of cost.
Due to the fact the FEL would be used minimally by me other than for snow, I thought that the blade
my be a more cost effective answer.
I live in New England and have turf tires. How is your 4100 configured to use the 54" blade for snow ?
Also, do you ever use the blade for dirt work ?
Thanks, Gavin
   / Front Blades on 4100 #5
Gavin,
My 4100 is gear drive, with R4 tires. Our driveway is gravel and about 800 feet long. We have had fairly mild winters since I have had the 4100, but so far it has been fine. I think chains will make a big difference if you have many hills. If snow is heavy, I plow only down hill and have no problems. I usually end up plowing early in the morning when time is important, and the angled plow is much quicker than the FEL.
I have used the plow for light dirt moving (cutting swails, etc.), but the light weight of the tractor limits what can be done. Most of the dirt work I did, I would hit the area with a tiller first, then move it with the blade. I added the FEL and toothbar this spring, and the uses for the tractor have multiplied.
If you are in an area of New England with tons of snow (we only average 50 inches or so a year in western PA), a blower might be more effective (to throw it away from the drive).
Hope this helps
John
   / Front Blades on 4100 #6
The problem with using a blade, or a FEL, for plowing snow is finding a place to put all the snow. I used my FEL for clearing our driveway at the house and the barn this past winter and it worked fine, but we don't get as much snow as you do in NE. If I lived in NE and had to choose between a FEL and a front blade for moving snow, I'd chose the FEL. At least with the FEL, you can move the snow if the piles get too tall. However, if you have plenty of room to push the snow, go for the blade.
   / Front Blades on 4100 #7
Yep, mine cost approx $1000 bucks when I bought it. For plowing snow, as long as you have somewhere to push it, it works great.
   / Front Blades on 4100 #8
Mike; a lot of the tractor owners in NE in my area use a blade or the FEL, when they want to change, most go to a snowblower. The FEI can be a lot of back and forth work from what I have observed. I use the blade and yes, as long as you have some where to push the snow, it really works well!
   / Front Blades on 4100 #9
I agree, Nuru. For those areas that get a lot of snow, the snowblower is the best choice. I had a front blade for my Wheel Horse and the first year I had it we got a blizzard and every spare location around our driveway had snow pushed in it. I even pushed snow across the street onto the berm, which resulted in a firm, but nice, reprimand from the township snowplow driver. /w3tcompact/icons/smile.gif I went and bought a walk behind snow blower the next year, which is an alternative to a 3ph snowblower at a half to a third of the price.
   / Front Blades on 4100 #10
Mike, I am still holding out. I did not have to use weights or chains yet, but I am slowly building a set of home made weight brackets for my universal weight I retired earlier this year.
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52141)
2018 FREIGHTLINER...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
UNUSED FUTURE 24" HYD TILT MINI EXCAVATOR BUCKET (A51244)
UNUSED FUTURE 24"...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
2007 WESTERN STAR 4900 (A52472)
2007 WESTERN STAR...
John Deere GP Tractor (A50514)
John Deere GP...
