Grading Front Blade for B2400
   / Front Blade for B2400 #1
porky69
Coaldale, Alberta, Canada
2009 Massey Ferguson GC2400
Can any one tell me if the front blade for a '98 B2400 uses the same mounting frame as the snowblower?
I ask because my father in law's tractor come with a FEL and snowblower when he purchased it used and while these are handy there are times when a front blade would be more convenient, and since I have recently aquired some welding/cutting tools I was thinking about using the snowblower mounting frame and lift cylinder and making a front blade with power angle (tractor already has the hydraulics so why not).
   / Front Blade for B2400 #2
i was told by the dealer that the mounting kit for the 2019 blade is different than for the 2550 and 2560 blowers.
search around some dealers -- they still have the 2019s in stock, though last time i checked, you need holes drilled in your loader frame to mount the plow sub-frame.
   / Front Blade for B2400 #3
If you are willing to use your tools to modify a blade from something else, i see no reason why you couldn't mount a blade the same way the blower mounts. I have the B2650 blower on my B2400, and i'd say it looks plenty stout enough to handle a reasonably sized blade. Just use the same pins for the blade to pivot on, and mount the lift cylinder in the same locaton on the blade. Use the curl circuit on the loader valve to angle...... obviously you will be able to float the blade just like you do with the blower. Take lots of pics for us when you do it !
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2013 Chevrolet...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A53473)
2006 Magnolia Dry...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2011 International ProStar T/A Day Cab Truck Tractor (A51692)
2011 International...
Kivel 48'' pallet fork attachment, 3500# capacity (A53421)
Kivel 48'' pallet...
