Grading Front ballast necessary for box blade?
   / Front ballast necessary for box blade? #1
2Malamutes
Bronze Member
Kalamazoo, MI
I have a BB2048 Frontier Box Blade coming Thursday, and I don't know if there is any reason to add some front ballast to my 2320. I'm going to be tearing up some poorly established lawn for landscape beds and reseeding, so really not major work. I think it weighs around 350 lb. which would seem light enough to me that it wouldn't warrant ballast but I don't know. Any need for some suitcase weights?
   / Front ballast necessary for box blade? #2
You certainly won't need it when you get your 200CX as that is plenty of weight in the front. Without it -- I'm not sure. When the BB is full of material, you may have to run with the MFWD on and lack of front weight will probably give you less traction (and help) from the fronts.
   / Front ballast necessary for box blade? #3
You'll know if you'll need front ballast when you try to raise that box blade.
I do not use front weights when mowing with a 400 lb befco finishing mower, but my 790's front end gets a bit light if I raise the mower to transport. This is with the loader removed.
Your 2320 is a lighter machine. I'd suggest trying it without the front weights (and loader off, if that's how you plan to work) and see how it goes.
As flyngti wrote, leaving your loader on would provide quite adequate front weight.
   / Front ballast necessary for box blade? #4
Run thru it with the rippers down to soften it up.. then drag the top soil out you want to remove.
Soundguy
20' One Trip Shipping Container (A50514)
20' One Trip...
International 5488 2wd Tractor (A52128)
International 5488...
UNUSED AGT MX12RX EXCAVATOR (A51243)
UNUSED AGT MX12RX...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
Maverick 3250 Excavator Hammer (A50774)
Maverick 3250...
New Holland B95 Backhoe (A50490)
New Holland B95...
