Front axle
   / Front axle #1
ideburger
Batesville, IN
Ford 861
The front axle pin came out on my Ford 861. I guess front end loaders are indeed hard on the front axle parts. The pin is the heavy duty threaded style (part # 312659) and that part seems readily available.
I cannot find the front axle pin bushing (part # 312661) anywhere on the internet. My local New Holland dealer carries it but the price is $153. That seams awfully high to me. Anyone kjow where else I can find this bushing?
Seems odd that the pin is readily available but not the bushing.
Thanks.
   / Front axle
I checked and the OD of my bushing is roughly 2 3/32 inches.
   / Front axle #5
Most of the ones I see are 2.18 or 2.19 OD roughly 2 3/16 OD. Was your bushing wore thru and your hole waddled out at all? Since most axle bushings sell for between $4/$15 no way would I pay the amount the dealer quoted you. If you can't find it I would get the axle pin and bushing close enough and take the axle down to the machine shop and have them machine the axle to fit the bushing. I doubt if the cost will be that high plus next time you need the bushing it will be in the $4/$15 range. You can call around to a couple of shops to get a ballpark price.
Kirk
   / Front axle
According to the New Holland online parts store, the OD of the $ 153 beauty is 2.124 in (actually listed as 53.95 mm). The bushing was not wore much at all. A piece of it broke off and left me with 75% of a bushing.
The hole was slightly waddled, but not much play between the two. I have determined that a 2 1/8" OD bearing should do the job.
I ordered one shipped ftom ASB Bearings for $24. I will report back how it works.
I am also a bit concerned that the threads that accept the axle pin may be wore. I will find out when the new pin arrives as the male threads on the old pin are wore badly.
   / Front axle #7
easy to get around either issue as you can make a keeper tab / tack weld.
as for the bushing fit to the axle, if it is wore, you can weld and grind or braze and grind if you want a super tight fit.
   / Front axle #8
When I did my Jub.... The hole was so worn and cracked I spent not much more than that on a new axle with bushing installed!
2004 Cherokee Lite 28A 30FT T/A Travel Trailer (A51694)
2004 Cherokee Lite...
2003 GROVE TMS500E MOBILE TRUCK CRANE (A51406)
2003 GROVE TMS500E...
2014 Ford Taurus SE Sedan (A51694)
2014 Ford Taurus...
Kivel 48'' pallet fork attachment, 3500# capacity (A53421)
Kivel 48'' pallet...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
