Front axle seal replacement
/ Front axle seal replacement #1
sikboater
Any one done a front seal replacement on a Massey Ferguson 1240 4 wheel drive?
I have attached the picture and the seal that is leaking is part #17. This looks to be a pretty simple job. 4 bolts to take the joint apart and then probably replace the bushings, and seals. Bolt back together and fill with fluid..
Any issues I might run into? Maybe reasons I should have the shop do it? I know the seal I need to replace is about $90 and the shop tells me 3 hours of labor, but they have never done this tractor.... I don't think the bottom bearing needs replacement (does not feel rough)..
Any suggestions? Is this harder than it looks?
Thanks for any help in advance!
Tim
  • agco_1637321_IS633030-1_Picture.pdf
So I asked some others I know and I think the bushings would be the hard part of this.... I don't really have any tools to install them or remove them. I wonder if they are pressed on? One other thought was that it did not leak much until I lifted the front wheels off the ground.. Maybe just the bushing and seal on top are worn out??
Any help out there? Anyone done this type of job on a different tractor? Was it too hard?
Thanks in advance!
Tim
Morbark 30/36 Wood Chipper (A62613)
Morbark 30/36 Wood...
SANY SY50U EXCAVATOR (A63276)
SANY SY50U...
3pt 2 Row Bedder (A64119)
3pt 2 Row Bedder...
2011 Ford F-250 Pickup Truck (A61573)
2011 Ford F-250...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
