Front axle parts for Hinomoto N209
   / Front axle parts for Hinomoto N209 #1
Texfisher
Does anyone know where I can buy front axle parts for the N209. I broke the front left wheel spindle/hub casting. does any of the massey models use the same front end?
Thanks for the info. The tractor has been a great work horse aside from this last problem. I took everything apart on the front wheel hub and figured out a way to have my local machine shop make me a new part. It is going to cost $300 -$400 dollars but it should be stronger than the original piece. May end up fixing the other side also.
I did have problems with the electronic hydraulic controls to the point the tree point hitch would not work. Got irritated with the mess and yanked it all out and installed a manual valve. Works like A champ.
So, far the things I have had to do to the tractor have been fairly straight forward. Just takes a little patience to figure it out.
   / Front axle parts for Hinomoto N209 #4
I have an N239. I'd like to know how you changed your hydraulics. No problems with mine, just a pain to adjust it exactly where you want it when it jumps 3 inches at a time.:rolleyes:
Eugene
Formerly buppy69
I have some pictures that might help plus it will let you know if the yours is plumbed the same as the N209.
They are on a different computer so I will send them as soon as as I can.
UNUSED JCT 72" VIBRATORY PLATE COMPACTOR (A51248)
UNUSED JCT 72"...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
Quick Attach Skid Steer Plate (A51573)
Quick Attach Skid...
Pallet of (15) 10 Lug Misc Wheels (A51573)
Pallet of (15) 10...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
JOHN DEERE LOT NUMBER 124 (A53084)
JOHN DEERE LOT...
