front axle oil
   / front axle oil #1
Anonymous Poster
Epic Contributor
I have seen this discussed before but what kind of oil/grease are most of you guys using in the front axle of a BX2200?
   / front axle oil #2
What does your manual say...?
   / front axle oil
The manual says super udt or 80/90 weight gear oil. This seems like two totally different fluids and I just figured the tractor veterans on this board could tell me if one was better than the other for this application.
   / front axle oil #4
I stuck with the Super UDT. Seems to handle it really well, and that is what was in it when I got it. Didn't seem to be any reason to switch to anything else, although my dealer did say I could go to 80-90 if I wanted. It gets fairly cold around here in the winter, and the SuperUDT handles the chill better.
   / front axle oil #5
It's probably been at least a year and a half ago that we discussed this at some length. It really does seem odd that Kubota would recommend either/or with two oils that are so different. I don't think anyone ever came up with a definitive answer (thicker oil may provide better lubrication in some places while the thinner oil might get into tight places the thicker oil didn't reach?/w3tcompact/icons/laugh.gif). Anyway, the only ones I know of came originally with UDT or Super UDT, so I decided to stay with that.
   / front axle oil #6
I went with Amsoil Tractor Hydraulic Fluid, same as in the HST.
John Bud
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A53473)
John Deere 1110...
2025 CFG Industrial QK20R (A50123)
2025 CFG...
2015 Ford Expedition EL SUV (A51694)
2015 Ford...
Ford Super Duty 8ft. Truck Bed (A51692)
Ford Super Duty...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2007 Anderson 25ft T/A Flatbed Equipment Trailer (A51692)
2007 Anderson 25ft...
