Front Axle Oil Seal
   / Front Axle Oil Seal #1
Mikeydpl
Cornwall. England
Mitsubishi MT 180D
Hi, this will be my first Thread as just joined
I have a Mitsubishi 180d 4 wheel drive,the outer casing on the front Axle needs a new oil seal,the seal is quite small approx 45 mm outside diameter and approx 42 mm inside diameter,I can't seem to get one anywhere,can anyone help?
Thanks M
   / Front Axle Oil Seal #2
I believe these are the same as those on the Satoh S373D. I bought some from Small Import Tractor Supply. I'd recommend replacing the bushings as well since if they worn your seals won't hold, or at least won't last as long. Just realized you're in England so I'm not sure on the shipping rates...
Hi,thanks for reply,I will have a look at what you suggested,like you say shipping rates could be high,kind of hoping theres someone on the forum from the uk that might be able to help,thanks for info though much appreciated.
2015 GMC SIERRA 2500 SERVICE TRUCK (A52576)
2015 GMC SIERRA...
2025 New/Unused Wolverine 32in Hydraulic Backhoe Excavator Thumb (A51573)
2025 New/Unused...
Unused 2025 Spirit Mini Golf Cart (A51694)
Unused 2025 Spirit...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
2019 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
