Front Axle Oil for Massey Ferguson 1736
   / Front Axle Oil for Massey Ferguson 1736 #1
DarMar
Bronze Member
Leander, Texas
2014 Massey Ferguson 1736
I did the 50 hour service yesterday. After I drained the oil out of the front axle, I double checked the owners and service manual to verify that it required the Permatran III oil just like the transmission. Both manuals state that it uses Permatran II not III. I am assuming that it's an error in the manuals since I can't find any information on Permatran II on the internet. Any help is appreciated.
   / Front Axle Oil for Massey Ferguson 1736 #2
I would agree on the typo. Permatran III is what you want in there.
MFRED, thanks for the verification. All research led to Permatran III (or equivalent) so that is what I put in this morning.
   / Front Axle Oil for Massey Ferguson 1736 #4
My 1423 recommended Permatran or SAE 80 gl-4. I end up putting in 80-90 weight oil. Runs fine.
   / Front Axle Oil for Massey Ferguson 1736 #5
The front axle is designed to use either hyd/trans fluid or 80W90. The reason the factory uses hyd/trans oil instead of 80W90 is it is easier for the owner to keep 1 kind of oil on hand. If you happen to have a front axle that weeps oil, an easy fix it to replace the factory oil with 80W90
   / Front Axle Oil for Massey Ferguson 1736 #6
The correct fluid is the same as the hydraulic system, Permatran III or Permatran 821XL. Unfortunately the manuals have various misprints. When draining the factory oils from the front axle or transmission it may appear more viscous than the Permatran fluids. Don't let that concern you, the factory oils are slightly more viscous but Permatran is correct going forward.
jeepcj7 and jsftractors, thanks for the help.
   / Front Axle Oil for Massey Ferguson 1736 #8
Thank you everyone for your responses and guidance.
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2006 FORD F-750 WATER TRUCK (A50854)
2006 FORD F-750...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
