Oil & Fuel front axle oil change 2310
   / front axle oil change 2310 #1
pathman
Val Belair Quebec
MF GC2310TLB
HEy all, I was doing my first 50 hr oil change yesterday and when I went to drain the oil from the front axle, I couldn't get the 2 14mm drain bolts out. I stopped before anything broke, I'll try again with an impact gun tonight. Any of you had this problem? BTW I went the permetran for this change, I'll have to look into getting some synthetic for the next.
   / front axle oil change 2310 #2
The plugs on mine was tighter then they needed to be but they did come out. Try a 6 point socket on a breaker bar before using a impact. If you do use a impact make sure you do use a 6 point to try and save the frustration of drilling and trying to remove the striped plug.
Doug
my thoughts exactly, I did use a 6pt socket and no I definately don't want to start drilling out bolts.
2021 Dodge Durango GT AWD SUV (A50324)
2021 Dodge Durango...
Crosley 10ft. Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
2001 Club Car Carryall Utility Cart (A51691)
2001 Club Car...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
2018 JLG 3246ES 32FT. Electric Scissor Lift (A51691)
2018 JLG 3246ES...
2008 CATERPILLAR 140M VHP MOTORGRADER (A51242)
2008 CATERPILLAR...
