Apr 21, 2006 / front axle leak #1 P pastormikey New member Joined Mar 26, 2006 Messages 13 Location erwin, nc Tractor kioti lb1914 i own a lb1914 and i have notice a oil leak right at the cap on the front axle. anybody have any idea what is causing the leak i see no cracks in the fill cap and i don't see any seal leaks.
Apr 23, 2006 / front axle leak #2 K Kiohio Platinum Member Joined Sep 6, 2002 Messages 547 Location Nelsonville, Ohio Tractor Can't remember.... Could be too full. Take it off and clean the cap and check how full the axle is. The cap is also the vent for the front axle. KO
Apr 23, 2006 / front axle leak #3 K KiotiJohn Super Member Joined Jan 21, 2004 Messages 6,317 The oil should only come up to about the middle of the indicator inside the glass front. If you overfill it, as stated earlier, it will overflow. If this is the case, let some out until you can see the level at the halfway mark. John
