Oil & Fuel Front axle fluid
   / Front axle fluid #1
jtheise4
SE Michigan
Massey Ferguson 1643 & Allis-Chalmers D14
I wanted to get some opinions on what fluid to use in the front axle of my MF1643. According to the owners manual, it states to use Permatran III, but that seems really thin for axle gears. I'm inclined to use Mobi 1 75W90 synthetic. What are others using? Thanks.
   / Front axle fluid #2
If your manual is worded like mine, it says something like: Permatran III -or- SAE 80 GL4, which is gear oil.
Permatran is fine in there, and not as thin as you think. The viscosity difference between that and SAE 80 gear oil, is not that great.
If you want the highest level of protection, use any GL4, or better, synthetic gear oil in that general weight category, with the EP, (extreme pressure), designation in the name. That's as good as it gets.
I am using: Amsoil Severe Gear® Synthetic Extreme Pressure (EP) Gear Lube 75W-90 (SVG)
   / Front axle fluid #3
Using Full Syn 75W90 in our front axle. (MF 1635.)
Had to take the front tires off, as this was the only way to get the vent plugs out on the top of each side of the axle.
   / Front axle fluid
Really? On the 1643, it only has one fill/vent plug on the right side and then the two drain plugs on each side of the axle. No need to take the wheels off thankfully!
   / Front axle fluid #5
Actually, yours is the same as our 1635, except for the 4cyl. On the top of each final drive case is a vent plug, and removing it makes it easier to fill the final drives properly. If you do not take the out, it takes a lot longer to fill them, can be done, but takes longer.
They help purge the air out of the final drives.
Fill/breather plug.
Final drive breather right side.
Final drive breather Left side.
So much easier to remove them, but had to take the tires off, as they are in tight, and could not get a ratchet on straight.
I have the factory service manual for the 1635/1643, so if you need to know anything specific, feel free to ask, and I can scan it for you.
   / Front axle fluid #6
Fill/breather plug.
Looks like a 'box end wrench' will fit right on there in the first pic.:confused:
   / Front axle fluid #7
Yes, but the Gorilla that tightened on the oil filter, also tightened these on. Used a ratchet/socket, as it was the easiest way to get it off.
Plus, I do not have a box end wrench with that long of a handle, leverage made it easier with a longer ratchet.
   / Front axle fluid #8
I use a box end wrench, that has the open end on the other...........then grab another box end , and put it on the open end of the first, makes for a long reach:thumbsup:
   / Front axle fluid #9
Taking the wheels off made it easier to drain it, less mess.
   / Front axle fluid #10
You didn't post a pic of the drain.......... if it's on the final drive, then it could be messy with the wheel on.
Unless one diverts the flow with something like the cardboard tube from paper towels or toilet paper.
2014 CATERPILLAR 304E CR EXCAVATOR (A51242)
2014 CATERPILLAR...
International 140 Tractor (RUNS) (A50774)
International 140...
2015 Freightliner Cab & Chassis (A47384)
2015 Freightliner...
2016 Dodge Charger SRT Hellcat Sedan (A50324)
2016 Dodge Charger...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
