Front axle fluid level
   / Front axle fluid level #1
dcsco
North central North Carolina
Kioti DK5510; MF TO-36; Case 580b
My dk5510 had no oil on the front axel dip stick. Drained about 1 gallon and refilled with about 1.4 gallons. I drained on left and right sides, but missed the center drain bolt.
Question is if the level is checked by dip stick screwed all the way in or just insert dip stick without engaging threads?
I assume that level is checked without screwing it in based on the level and the amount of fluid replaced.
Thanks all
   / Front axle fluid level #2
I wrote a question about this too for my CK2610. I had read elsewhere that your approach is correct- don't screw in threaded dipsticks, press in the ones with O-ring type seals. So I filled to the mark without screwing it in.
I was glad I followed another poster's advice which was to check the level frequently immediately after changing the fluid. There must be some nooks and crannies that don't fill immediately, even after operating in 2WD/4WS, as mine had to be topped off at least two-three times afterwards before it stabilized level.
For what it's worth, Toukow
Fifth wheel multi use trailer. (A52128)
Fifth wheel multi...
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
John Deere 331G SKID STEER (A50322)
John Deere 331G...
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
Brown 417 7ft Rotary Cutter (A50490)
Brown 417 7ft...
2018 HINO 258 S/A SERVICE TRUCK (A51243)
2018 HINO 258 S/A...
