Front Axle Float Adjustment
   / Front Axle Float Adjustment #1
Venturabass
Bronze Member
Central MA
Kioti DK5310SE
Hi All,
I am a newer owner to a 1997 Massey Ferguson 1240 compact tractor. I recently picked up the shop manuals, and when I was reading through them I came to a section that discussed adjusting the front axle float.
I did some searches for axle float on the forums but didn't find anything. I searched google and got a basic understanding: a full floating axle doesn't support the vehicle weight, it only transfers torque to the wheels.
But I'm still unsure of "adjusting front axle float" is, and if I even need to bother with this? Could anyone give me a better explanation?
Thanks.
   / Front Axle Float Adjustment #2
I'm pretty sure they're talking about the play in the front axle center pivot. If I remember correct the pivot has an adjusting bolt to adjust the fore-aft play.
If you pick the front axle up with the loader, grab one of the front wheels & try to move it towards the front and rear of the tractor, that's what you would be adjusting.
Different than a full floating axle in a vehicle.
So you're saying if I put the FEL loader bucket on the ground, and use it to lift the front end of the tractor off the ground, I can pull on the wheels and make the axles move fore and aft?
Any idea if this is something I need to actually adjust? Have you ever checked/adjusted this? I do recall seeing that screw. The tip of the screw points to the back of the tractor.
Trommel (A52377)
Trommel (A52377)
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2012 Mitsubishi Outlander Sport AWD SUV (A51694)
2012 Mitsubishi...
2025 K0311 UNUSED Galvalume Corrugated Steel Panel (A53117)
2025 K0311 UNUSED...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
