Buying Advice front axle advice
   / front axle advice #1
arthr31
Platinum Member
new england
3 Yanmars
Hi all,
...Need some pointers/advice here. I'm trying to change the front axle fluid on my 1601. However, I can't budge the "filler nut" that is on the top of the right-hand side of the axle. I'm using a 1 1/8 socket and trying with all my measly might. I haven't tried a breaker yet, but worry about doing so. Also, I'm worried about stripping the nut and then being really lost!
Any suggestions for me? Also, I am looking at the right nut for the oil fil hole?
Thanks. -art
   / front axle advice #2
Arthr31,
Sometimes you just have to use the breaker bar. I have seen them too tight, missing the nylon or rubber gasket and don't know why people do that. I've never broken one yet.
Good luck,
Mark
   / front axle advice
Thanks for the reply, Mark. Follow-up question, is a 1 /18 socket the right size for this bolt? I sized it up pretty good with a caliper and took it to the hw store but that was the closest size I could get.. Thanks, -art
   / front axle advice #4
You also might want to use some PB blaster, on it and let it soak for a while, or better yet if you have some Koil, I hope I spelled that right, it is even better. I'm sure it will help some. Walmart has the PB Blaster.
   / front axle advice #5
Since these tractors are metric, I would bet it is a 28mm, though 1 1/8" is only .575 mm (about .023") larger. The 1 1/8" socket should work ok.
   / front axle advice
thanks for the response guys. I went and got some liquid grease today and a new breaker. I'll try in the AM to get this bolt off.
Mark, you mentioned that you've seen washers missing on these axles. Is there supposed to be a washer of some type on the 1601 front axle? I definitely don't have one... Thanks. -art
   / front axle advice #7
An old mechanics trick is to gently tap the top of the bolt a few times. Then using a drift pin and hammer, give the bolt a rap at 12/ 3/ 6/ and 9 o'clock on the flats of the head. This will help to break the bolt loose. If that doesn't work, then you can apply some heat to the head of the bolt. Sometimes these bolts are installed at the factory with a Loctite product so they won't work loose while the tractor is in service. If when you get the bolt out, you find that there is a blue or orange substance on the threads, that is the Loctite product. If that is the case, then it should be renewed when reinstalling the bolt. There is no substitute for the proper socket. If the bolt head is a metric size, then you should use a metric sized socket. The gripping force of a socket isn't at the edges of the hex, but rather at the middle of the hex. If you use the socket that is close, it will put pressure on the edges of the hex and this can cause the edge points to fracture and round off. There is no substitute for the proper tool. Also constant pressure as applied by a breaker bar is the way to go. If that doesn't work, don't force it, get a longer bar. I have rarely seen bolts shear when you are trying to loosen them, but have seen many shear by over tightening them.
   / front axle advice
Thanks again for the input, guys. I finally got a chance to work on this today-- I used some liquid grease, let it set while I changed my fuel filter and cleaned out the bowl. Then, tapped the bolt a few times, all around and on the head. Didn't even need a breaker after that!! I did tighten it a tiny bit before getting it to back off-- this was recommended to me...
So, now I have another question, more like a riddle. How long will your front-wheel drive work in a yanmar with nearly no oil in the axle?
(Answer: Apparently for at least a year!!! /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif I only got a few oz of sludge to come out of the axle housing!!!! I'm going to fill up with 80w-90 and then probably change it again after the winter. )
Thanks. -art
   / front axle advice #9
I'd recommend draining the axle first. I too found my axle to be out of oil. I topped it off and found the leak to be a bad axle seal. When I drained the axle all the oil was contaminated with water from the prior owner.
   / front axle advice
Thanks. I discovered how much was there because I was draining the axle. No sign of a bad seal, however. I should also note that once I drained the two bevel housings for the wheels, I finally ended up with about 1.5 litres +/- of sludge. I figure that it has been a LONG time since the axle oil had been changed...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
JLG 1255 Telehandler (A52128)
JLG 1255...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
Craftsman LT2000 42in. Riding Mower (A49346)
Craftsman LT2000...
2016 Nissan Sentra Sedan (A50324)
2016 Nissan Sentra...
PLEASE VIEW ALL PICTURES!! (A50774)
PLEASE VIEW ALL...
