Front Axel Noise 3215
   / Front Axel Noise 3215 #1
wimpy525
PA
Mahindra 3215 HST
I have a 3215 with about 400 hrs on it. While working to day the front axel started making noise. Only makes noise with 4 wheel drive engaged, leading me to believe the drive shaft may be to problem. Anyone else have this problem? Also any know where I can find a break down of the front end?
   / Front Axel Noise 3215 #2
Check the couplers on the front driveshaft, have seen the snap ring let go and coupler slide back and have seen peolpe run in 4wd on hard ground and stip the couplers. Here is the link to the front driveshaft and couplers
Error
Thanks johnsonauto front end of the drive shaft is shot as well as the coupler. This is my doing I run this tractor hard and has been a great tractor.
I see I posted this in the wrong section so if the mods want to move this post.
Thanks for the help.
   / Front Axel Noise 3215 #4
Your welcome, glad you found the problem.
2013 John Deere 544K Articulated Wheel Loader (A50322)
2013 John Deere...
2017 Nissan Murano SUV (A50324)
2017 Nissan Murano...
2022 Adams CLC-1013 Conveyor - New (A52128)
2022 Adams...
2009 PETERBILT 388 TANDEM AXLE DAY CAB (A51219)
2009 PETERBILT 388...
1997 GROVE TMS750B 50 TON CRANE (A51222)
1997 GROVE TMS750B...
2015 FREIGHTLINER CASCADIA DAY CAB (A51222)
2015 FREIGHTLINER...
