Front 3pt Hitch
   / Front 3pt Hitch #1
Mark Page
Platinum Member
Maryland
Massey Ferguson 2615 48hp, 4wd, loader
Why not build a tractor with the 3pt hitch on the front. It would make it easier to hook up implements, see what your doing when mowing, pushing or blowing snow, digging post holes, grading gravel or a million other things. Probably be worthless for plowing. It works pretty well on BobCats, why not tractors?
   / Front 3pt Hitch #2
You may be aware of this already, but this is an option on larger tractors. And on those tractors, the front hitch can hold quite a bit of weight.
I'm guessing the reasons you don't see it on smaller ag tractors or utility tractors are:
- Additional complexity would add unreasonable cost at that price range
- Utility tractors don't have front frames and axles heavy enough to support a front hitch (but they do handle front loaders which may mean they are heavy enough)
- You can't really see better when the implement is up front. I have an FEL on my tractor and one of the things I don't like is I can't see where exactly the bucket edge is while I'm sitting on the tractor. When I have something on the rear 3pt, I can generally see exactly what it's doing be just turning around and looking down (but it is challenging to drive straight forward while looking backwards).
   / Front 3pt Hitch #3
I was just thinking about this for light duty work the other day. I have a long lane with gravel on it that I level with a box blade. For the finishing work, it would be great to be able to push the bb along.
   / Front 3pt Hitch #4
It's an option for my JD 6415. They even have a version that folds up out of the way for front end loader use. There is also a front PTO option
   / Front 3pt Hitch #5
My tractor is fully frontloaded. Just like a skid steer. Currently designing a 3pt hitch for the rear.. Why? because using the FEL arms to push a box blade or similar gear doesn't work. the geometry of an FEL creates a tendancy for the tractor to climb up and over the box blade in float mode. Now mowers, it is complete heaven. having the mower out front is great... I would think, though, that you guys with a single wheel hog would have to modify to a 2 caster wheel system... lots of pressure on a front mower... I also have an 8ft york rake that, with wheels, works like a charm out front...
   / Front 3pt Hitch #6
Quite common on tractors in Europe...just starting to see it on the larger AG tractors over here.
   / Front 3pt Hitch #9
That's exactly what I was planning to do. I was planning to use my old HF quick hitch , design, build and weld a bracket system that would fit Skid steer quick attach for my Kubota L4600 to allow use of landscaping rake and boom pole.
JC,
   / Front 3pt Hitch #10
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
2025 Wolverine EX-66-84L Pallet Fork Extensions (A53117)
2025 Wolverine...
Killbros 260 Seed Conveyor (A53473)
Killbros 260 Seed...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2012 Chevrolet Silverado 3500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A51246)
JOHN DEERE 437E...
