TheMan419
Veteran Member
I bought a new tiller. Tarter 5 foot. The manual that came with the PTO shaft is at best useless. A copy can be found https://static1.squarespace.com/sta...5e231ae03b502ad/1488981138666/PTO-Booklet.pdf
According to this manual I have a "Friction Torque Limiter". Is that the same as a slip clutch? If so I would certainly like to properly maintain it and adjust it before I use the tiller.
The manual helpfully explains that I should check for proper operation and the torque can be changed by turning the 8 nuts that hold the thing together. It should be turned 1/4 turn and then check for proper operation.
However nowhere in this helpful manual does it tell me what proper (or improper) operation looks like.
I am a hobby farmer so I work a day job. I can call Tarter, but not while I am sitting in front of the PTO shaft. So I am looking for sage advice from this group.
Is this a slip clutch and how do I check for proper operation?
Thanks as always to this brain trust
