Fresh system, old implements...
   / Fresh system, old implements... #1
tshep
Richmond, VA
BX23 MLB
Hi all! I changed my BX23 transmission and implement fluid for the 300 hour service. I did NOT have the loader or backhoe on, and I tried really hard to give all the fittings a chance to drain (held pins in and waited, etc). Seemed to really 'pep up' the tractor motion and I believe it sounds better too.
Now, I really hate the idea of adding those implements and their dirty oil back into the system. Anyone got a procedure to drain, and maybe refill implements either off the tractor or when going back that will minimize mixing? The FEL section is all hoses (no valves as it sits, valve stays on tractor) and the BH has the valve manifold attached and hoses looped together - a feed and hi pressure return if I recall.
I don't think I can manipulate most of the cylinders manually (attached) to empty and suction fill - I've hit my limit in age vs strength.
Any suggestions? I will probably want the FEL right soon...
   / Fresh system, old implements... #2
In all honesty I wouldn't worry with it.
But you could unscrew the hose ends (that plug into the tractor) on the return side and put them down if a 5 gallon bucket or barrel. Then just plug in the other hose and work the lever. By putting new oil through it would push the old right out. This may require one person to hold the hose in the bucket as it may tend to fly back out.
I did this to our post driver because the oil in our JD was milky (water) It had been powering the post driver and I did not want that crap in my new Kubota.
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Forestry Mulcher (A53473)
2022 JCB 3TS-8T...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
