Freezing shop supplies
   / Freezing shop supplies #1
DaveNay
Platinum Member
Waterman, DeKalb County, Illinois
John Deere 855 MFWD; Oliver 1850 Gas
With winter approaching, I am considering building a heated cabinet for my shop. I would like to put items in here like PVC glue, caulk, cans of paint, adhesives, spray lubricants, etc. How much of this type of stuff really needs to be protected from freezing? I was thinking of a simple plywood cabinet, some ridgid foam insulation and a 40 watt light bulb on a thermostat switch. I don't need to keep it real warm, but 40-45 F would be nice.
For you southerners and Australian desert dwellers, freezing is when the ambient air temperature drops below 32 degrees F or 0 deg C, and water based products turn into a solid. /forums/images/graemlins/smirk.gif /forums/images/graemlins/smirk.gif
Dave
   / Freezing shop supplies #2
I just move all Latex based paints, caulk, etc into the basement and leave them there. I leave Oil based paints, RTV, solvents, etc in my workshop, which is not heated all of the time. Has worked so far.
Not sure on your idea of a heated cabinet, probably will need some insulation at least.
Ben
   / Freezing shop supplies #3
an old fridge might work as well and save construction costs. even has light sockets although some rewiring would be in order to add thermastats.
   / Freezing shop supplies #4
Dave -- Over the years, having lost a lot of stuff to winter cold, I've developed a system. Anything subject to damage or loss from freezing that is normally kept in the shop or garage in warm weather has a blue band around it. I use blue electrical tape. About this time of year, with the first freezing spell just around the corner, I go thru the unheated spaces with a tote, gathering all the blue striped items and moving them to the basement.
For all you folks who confuse "chilly" with "freezing," even cans of WD-40 are rendered useless by a few days of minus 30. The spray mechanism gums up and never recovers, so every spray bottle or can, no matter what's inside it, is a blue stripe item.
I've never relied on heated storage since around here the power supply in winter is subject to failure.
Pete
   / Freezing shop supplies #5
<font color="blue">so every spray bottle or can, no matter what's inside it, is a blue stripe item </font>
OK Pete, what the heck is a <font color="blue">blue stripe item??? </font>
/forums/images/graemlins/smile.gif
   / Freezing shop supplies #6
</font><font color="blue" class="small">( OK Pete, what the heck is a blue stripe item???
)</font>
I bet it's Vermont's version of K-Mart's <font color="blue"> Blue Light Special </font> ! /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif
   / Freezing shop supplies #7
Dave,
<font color="blue"> For you southerners and Australian desert dwellers, freezing is when the ambient air temperature drops below 32 degrees F or 0 deg C, and water based products turn into a solid. </font>
I will tell you how to store stuff in winter if you tell me how to keep my beer cold in 45c
   / Freezing shop supplies #8
</font><font color="blue" class="small">( </font><font color="blueclass=small">( OK Pete, what the heck is a blue stripe item???
)</font>
I bet it's Vermont's version of K-Mart's <font color="blue"> Blue Light Special </font> ! /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif )</font>
Jeez, you guys don't really read posts, do you? /forums/images/graemlins/smirk.gif
I put a stripe of blue electrical tape around every container in the garage or shop that has to be removed before freezing weather arrives. Pete
   / Freezing shop supplies #9
</font><font color="blue" class="small">( Jeez, you guys don't really read posts, do you? )</font>
Actually Pete, I had planned on mentioning to Rob what you had put in your original post, because I had read it.
But it wouldn't have been nearly as funny! /forums/images/graemlins/smirk.gif /forums/images/graemlins/grin.gif
</font><font color="blue" class="small">( I will tell you how to store stuff in winter if you tell me how to keep my beer cold in 45c)</font>
Place your beer in a mesh bag, with a couple of rocks for weight. Tie the bag to a long rope...SECURELY! Tie the other end of the rope to something solid, and then toss the beer-in-a-bag into that nice cool river you have. Cold beer in about 30 minutes.
Dave
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A54814)
2012 Freightliner...
2011 Chevrolet Uplander Van (A51694)
2011 Chevrolet...
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2014 Ford F-150...
2013 VOLVO VNL64T TANDEM AXLE MID ROOF SLEEPER (A54313)
2013 VOLVO VNL64T...
