Freezers These Days
   / Freezers These Days #1
SPYDERLK
Super Star Member
VA
JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Whats with home freezers these days. Older freezers would do 20 Below. Now its -5 and maybe -10. This leaves no performance margin at all for good preservation. I had an older one, bought used, that I ran it for an additional 20 yrs myself. It would do a solid -20F til it wore out. We replaced it naively, assuming the experienced performance range was a given value for the purpose. The warm ones just dont keep food as well, and are too sensitive to a power outage.
Does anyone have a lead on where to look for Cold ones? The standard suppliers seem to be stuck in the warm range? :confused2:
Thanks,
larry
   / Freezers These Days #2
The majority are now coming from China. Plus, the use of freon types keeps changing for environmental regs.
We just got a three year old one off Craigs. Like new. $100. Very pleased, but as you say, I have doubts about it getting as cold as previous generation models.
   / Freezers These Days #3
I sure didn't know all this. We just bought a new freezer from Sears thinking the new models were better all the way around.
   / Freezers These Days #4
Take a look at the G/E ones. We have a couple of newer middle sized ones with adjustable temps. Put it all the way down when we are freezing stuff then can turn it down/up after it is frozen. It shows 30 below at the coldest setting on a thermometer (or however it is spelled) Advantage of having 2 is we can unplug one in the spring after we have been eating out of it all winter.
   / Freezers These Days #5
There's only like 2 manufacturers of freezers. my freezer that i bought new last year gets to 0 and thats it.
   / Freezers These Days #6
probably energy conservation regulations?Why must they be set so low? just to have that extra ooomph in a powerfailure?
   / Freezers These Days #7
I would look at a commercial freezer. Little pricey to run, but does the job. I had a 3 door TRUE given to me that had a compressor out, I fixed( I do refrigeration/HVAC) and works like a champ. In fact, cold control went bad and temp at -45. Auctions at closed restaurants are a good source. 72 cu ft. chuck full of fresh frozen meat, veggies, leaves a warm fuzzy feeling.::licking:
Thanks! That sounds like a good lead. I will check. Could you post Model #s?
larry
   / Freezers These Days #9
Interesting thread. I've been thinking about a newerer, more efficient freezer because hydro bills are creeping up above $215 per month. Maybe that's not such a great idea.
   / Freezers These Days #10
An average non-self defrosting chest freezer will take 6 months to use as much electricity as your average frost-free refrigerator uses in 1 month so energy use of a freezer is not nearly as important as that of a refrigerator.
There are no major freezer manufacturers left in the USA and only one that I know of in Canada and the rest are made in Asia.
Lowes and many other stores sell "commercial" models that will go down to -25 degrees.
2005 Mack Vision Semi Truck (NOT RUNNING)(TITLE) (A50774)
2005 Mack Vision...
2018 Gatormade 20+5 Gooseneck Trailer (A52748)
2018 Gatormade...
2022 Adams CLC-1013 Conveyor - New (A52748)
2022 Adams...
Unused 2025 CFG QK20R Mini Excavator (A50322)
Unused 2025 CFG...
2011 PETERBILT 367 TRI-DRIVE WITH TAG (A52472)
2011 PETERBILT 367...
Genie GTH-644 (A50490)
