Freeze protect water tub: aquarium bubbler?
   / Freeze protect water tub: aquarium bubbler? #1
CobyRupert
Super Member
Washington County, NY
JD 5075E
What are the chances a fish aquarium bubbler would work to keep a small water tub unfrozen?
   / Freeze protect water tub: aquarium bubbler? #2
probably low.
why not put a trough de-icer in it.
   / Freeze protect water tub: aquarium bubbler? #3
I have a 10x17 foot pond and use air to keep a hole open and did not lose any fish last Year
   / Freeze protect water tub: aquarium bubbler? #4
I spent time in your general area (Lake George) and it is common to use small compressors to bubble around docks to keep ice away from docks. Seems to work well.
   / Freeze protect water tub: aquarium bubbler? #5
I am an ice fisherman. I sometimes use minnows for bait. I can tell you from personal experience, that a small water tub with an aquarium bubbler will first get a layer of ice on top with a hole for the air. Then ice will form along the sides. Then ice will form on the bottom. Then you will have a block of ice with a cup of water in the middle bubbling a small stream of air out a hole the size of a dime. Of course, this all depends on the air temperature outside the tub, as well as the air temp the bubbler is blowing in.
What size tub are you thinking about? I have friends that have horses and they keep their water tanks open with a horse water tank heater, like what Soundguy mentions. They're commonly called stock tank heaters.
Tractor Supply Co. - Enjoy browsing:Stock Tank Heaters
   / Freeze protect water tub: aquarium bubbler? #6
I would think a combo of a small heater and a bubbler would be more efficient than just a heater.
A bubbler with a heater would be a slick product maybe?
   / Freeze protect water tub: aquarium bubbler? #8
you can buy water tubs in various sizes, with heaters built right in. They work great and are not expensive.
Hey, how small a tub are you talking, anyway? Just curious.
A 3'l x 2'h x 1.5'w -ish rubber tub, probably holds 50-60 gallons I'm guessing. Looking for a temporary solution that requires something less than 1500 watts. A permanent solution requiring a backhoe, trenching & running water/electric lines ain't going to happen this year. Had no heat last year and just had to break/dump the ice. No biggee.
   / Freeze protect water tub: aquarium bubbler? #10
Sounds like you have a live stock water trough. I use a 1500 watt heater in mine. It has a T-stat so it doesn't draw power all the time.
As for your question:A bubbler will just keep a small hole open... You might try an aquarium water pump to circulate the water and keep more of the surface from freezing. But, still ... the only heat you have is the latent heat of the 50 gallons, eventually it will freeze.
MURRAY 22" 2N1 SELF PROPELLED GAS PUSH MOWER (A51248)
MURRAY 22" 2N1...
2000 HONDA RANCHER 350 ATV (A51247)
2000 HONDA RANCHER...
FRONTIER WR3212 LOT IDENTIFIER 54 (A53084)
FRONTIER WR3212...
UNUSED CHERY INDUSTRIAL 14' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53473)
PENDING SELLER...
