Freeing a locked up miter saw
   / Freeing a locked up miter saw #1
AndyR
Lyndeborough, NH
Kubota L5030HSTC, Farmall SuperC
I've got a Delta miter saw that I had left tilted over the winter. When I went to use it the other day it felt as if the shaft lock was engaged /forums/images/graemlins/confused.gif I was able to confirm that was not the case and suspect something in the brake circuit but it is locked no matter what I do. (Large rubber mallets have already been applied - ng /forums/images/graemlins/frown.gif) There is about 1/8 inch of rotational play in the 10" blade but that's the best I can do. At one point I got it so I could rotate the balde partially by hand but as soon as I apply power it locks up. Anyone have any ideas or have had something similar?
   / Freeing a locked up miter saw #3
I have two of those saws but have never experienced such a problem...you have likely checked to see that nothing is binding the blade inside the upper housing.
I would remove the blade for safety reasons and then rethread the arbor nut on and try turning the motor using a wrench. If the saw worked okay the last time you used it I doubt if leaving it tilted would cause any problem. Any chance it got wet enough to rust the motor?
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
2003 Walk-Behind Automatic Seed Spreader (A51691)
2003 Walk-Behind...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
