Free Box Blade PLans
   / Free Box Blade PLans #1
Steven
Peabody, Ma.
KUBOTA BX-22
I found this site that has free cad plans. One was for a 60" boxblade if any one is interested.
box blade plans
   / Free Box Blade PLans #2
Nice link...
I remember many, many years ago ther was a tractor called a Farmette you could build.
I found it on the site also.
Mike
   / Free Box Blade PLans #3
Thats funnny, I just brought their backhoe plans off e-bay and they had info to the website and free stuff inside the packaged. Down loaded it this morning.
   / Free Box Blade PLans #4
One thing to check is I priced the scarifier shanks fron TSC and it was around $28.00 + shipping.
Add up 5 or 6 of these and u are 2/3 of the cost of a new box from TSC.
   / Free Box Blade PLans #5
I was thinking like you Hoeman00. I'd also looked at buying the teeth and building my own. I ended buying a 5' KK instead.
I plan to build an implement where I can mount the five teeth as a sort of ripper (without the box), so I should be able to pull them deeper than when on the box.
Plan to use that prior to tilling some hard clay soil.
Best wishes,
Ron
   / Free Box Blade PLans #7
Thanks Steven. I printed this out for future reference.
When I got my BX2200, I needed a ripper to bury some cable and a harrow to scratch in some grass seed after tilling.
I built a toolbar and made a mount for two ripper blades next to each other. I welded on some brackets so I could attach a homemade harrow (three rows of 6" 3/8 strap) That got me to thinking that rather than building the 3PT part for each implement, I'd try to build so I can add just the implement part.
All I need to finish the ripper is buy some rectangular tubing and weld it to the box beam member of my tool bar. Or I might just use strap and fix it so I can have a shear bolt arrangement to save the teeth......
Thanks for posting the reference!
Ron
   / Free Box Blade PLans #8
I know the price because of wanting to build the same thing box blade w/o box.
I bought a used 6' Landpride brush cutter and MD 7' blade, while I was picking them up he asked me if I wanted the 6 rippers from his box blade and 300gal. fuel tank since he won't use them.
So I threw them in too.
So I have 12 rippers now and some 10" and 12" H beam to use for frame.
I'm thinking 7' wide w/ 10 teeth to start out.
Also going to put some adjustable skids on it to set depth.
   / Free Box Blade PLans #9
Where did the site go? Was Re: Free Box Blade Plan
The link does not work any more...When I went there last, these was a note about moving the tractor information to a new site.
Does anyone know the new address?
   / Free Box Blade PLans #10
Do you have current website info for "free boxblade plans"? I can't seem to find. Thank you, Scott Kimmich
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A55973)
2015 Freightliner...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
LOT: (3) NEW Hi-Run 26 x 12.00-12 Lawn & Garden Tires (A59076)
LOT: (3) NEW...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
