FrankenFarmall
   / FrankenFarmall #2
Sounds nice running....I want to watch it pull a plow. :)
   / FrankenFarmall #3
Nice..darn nice workmanship.
   / FrankenFarmall #4
My guess is it can't. He doesn't say he swapped the trans, and the info on the placard doesn't mention it either, So my guess is he just adapted the V8 to the existing trans. The original 1936 tractor topped out at 1200 rpm and that is what that V8 sounds like it idles at.
Original trans was geared at 1 -2.3 mph 2 - 2.8 3 -3.3 4- 3.8 Your avg turn plow from the 40's was designed to be pulled between 3-4 mph which for most ground condition was likely 3rd gear.
SO ballpark 1000rpm at 3.3mph in third.... 1st is about 40% (slower) so that only puts you at 1400 rpm in 1st gear to do 3.3 mph. assume you pull that 2 bottom "fast" at 5mph you might be able to get that big V8 up to a whopping 2300 rpm.
At 2300 rpm you'd burn the clutch up trying to slip it enough to keep the RPM up high enough to get that 2 bottom started without stalling it.
Sad to say. Sound cool, but it truly is nothing more than a rolling billboard.
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
2016 Godwin CD150M...
UNUSED WOLVERINE PFF1-13-45W UNIVERSAL MAST (A51248)
UNUSED WOLVERINE...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A53472)
John Deere 6105E...
