Frame Mounted Plow, anyone have one/tried one?
   / Frame Mounted Plow, anyone have one/tried one? #1
avc8130
Platinum Member
Northern, NJ
Kubota L45
I'm looking to make my Kubota L45 more useful for removing snow from my 1/4 mile paved drive. My drive goes up and down twice so a total of 4 quick but steep hills (2 up, 2 down). I have a Fisher plow that I normally run on my pickup, but having a backup option is always nice. I've seen guys run the plows on the front of the loader arms, but that makes for a very long setup and I'm concerned it will push the front end around.
Here's what I was thinking:
Album:
My thought is to get a Fisher mount for a Dodge or Ford truck and then make adapters to mount it to the tractor frame where the grill/brush guard mounts. My goal would be to keep the plow as tight to the tractor as possible. I don't have front hydraulics so I'd probably wire up the plow just like it is on the truck.
Thoughts? Experiences?
Thanks!
ac
   / Frame Mounted Plow, anyone have one/tried one? #2
I made a subframe for my l3400, I love it and think it is by far the BEST way to mount a plow to a tractor. There is a build thread on here by ASGAR that I followed when I built mine. I tried the loader mounted option two different ways wi th a 9 footer on my JD and I was less than impressed plowing the same driveway. It was too long, the plow tripped easily, the loader would dig into the ground, yadda yadda yadda. So I converted it to a box pusher. The jd is cabbed and the kubota isn't hence the change.
Any chance you've got some pics?
   / Frame Mounted Plow, anyone have one/tried one? #4
I'm on my phone at the moment but I think I have some pics from the setup on the b7800. Same setup on my L. I might have some video still posted as well.
   / Frame Mounted Plow, anyone have one/tried one? #6
I have always used frame mounted truck-style plows on tractors.
As in since my Dad's first one set up in 1964 or so.
My favorite way to get the job done.
   / Frame Mounted Plow, anyone have one/tried one? #7
Should be fine, whats nice is that you have the weight of the hoe in back, that helps allot.
   / Frame Mounted Plow, anyone have one/tried one? #8
I don't think there is anything fundamentally wrong with what you want to do, but looks like too much plow for the tractor to me. Unless your truck is a total POS I'd keep the plow on there and just use the loader bucket if the truck went down.
I'm steering away from this concept. My main fear is the electrical demand on the Kubota. The Kubota only has a 45A alternator and 1 battery. The plow draws up to 200A when lifting/angling. That's known to tax alternators on diesel trucks, which usually have dual batteries and 160A alternators. The major fear is that the Kubota alternator is $450!
ac
   / Frame Mounted Plow, anyone have one/tried one? #10
Thinking out loud. What happens if you bought a cheap plow that was one that needed to be welded to the frame of a truck. Created a quick attach and used your tractor hydraulics? ?
If you dont understand I could possibly draw something up??
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A52748)
UNVERFERTH 330 -...
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A51572)
2016 Hino 195h...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
2009 John Deere 2020A Progator (RUNS) (A50774)
2009 John Deere...
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A52748)
2019 Tico Yard...
