Frame mount a LW-7 BH on a JM 354
   / Frame mount a LW-7 BH on a JM 354 #1
kbone1
St.Augustine, Florida
JM 354
I will try to put my LW-7 backhoe together this weekend and I am formulating what materials I need to fabricate a frame mount system for this backhoe to fit on my JM 354. Would ¼ inch plate be strong enough and hold up well to the stresses of a LW-7 backhoe on a JM 354? I will not build the frame mount yet but I figured that while I am assembling the LW-7 it would give me a good idea of how I was going to build the mount. If anyone has any pics, drawings, or tips on what they did, I sure would appreciate them.
kbone1
   / Frame mount a LW-7 BH on a JM 354 #2
JUST FINISHED CHANGING OUT A LW-06 FROM THREE POINT TO FRAME MOUNT I HAVE SOME PICTURES IF THAT WILL HELP ANY. I USED 2"X4" TUBING FROM THE LOADER ARMS BACK.
That would be great, any info, pics, measurements, drawings
whatever you will send I will use.
Thanks,
kbone1
   / Frame mount a LW-7 BH on a JM 354 #4
I have ordered a LW-7 3 point mount backhoe to put on a Kama 554 but I am toying with the idea of fabricating a frame mount. I have a koyker FEL. Please post any pictures of the frame mounts you have.
   / Frame mount a LW-7 BH on a JM 354 #5
Have you run the lw-7 on your machine yet?
If so are you using a pto pump of the rear remotes?
Are you happy with the Backhoe?
I'm considering one for my KM 454.
Scozz
   / Frame mount a LW-7 BH on a JM 354 #6
I have not even received my back hoe yet. Chip ordered it and it should be in Feb. sometime.
I plan on mounting it on the three point first to look at performance like that.
It is supposed to hook up to the remotes.
   / Frame mount a LW-7 BH on a JM 354 #8
HERE IS A PICTURE FINALLY GOT IT DOWN IN SIZE
2015 Ford Explorer AWD SUV (A51694)
2015 Ford Explorer...
PAIR OF 7' HOOK ON TRAILER RAMPS (A51247)
PAIR OF 7' HOOK ON...
2006 Peterbilt 335 Day Cab Truck (A53117)
2006 Peterbilt 335...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
Kubota RTV X900 (A50123)
Kubota RTV X900...
2025 K2010 UNUSED Chicken Coop (A53117)
2025 K2010 UNUSED...
