Foward/Reverse hydro help
   / Foward/Reverse hydro help #1
DrBlackrose
I bought a 1996 CC2185 that was neglected and it needed a little TLC. Part of its life was spent in the weather without any protection. I have most of the problems worked out and I believe I have a really good tractor. I am having a small problem with the forward pedal. If I am mowing at steady speed and attempt to speed up it wont, I have to completely lift off the pedal and push again to get a different speed. Now as long as I don't hold a steady speed (5 minutes or so) it will speed up normally. I have changed the fluid and filter with no change. I have looked under the mower and see the plastic bushings from the linkages are all brittle and worn. I have greased all pivot points on the linkages and still having same problem. I see a small black gas shock hooked to the linkage could this be worn out and causing this?
Thanks for what help you can give me! /forums/images/graemlins/grin.gif
   / Foward/Reverse hydro help #3
Are you 100% sure the go pedal is seeing a full range of motion when the loss of speed occurs? If the linkage is moving full range, it's gotta be something internal to the hydro drive. That little gas strut just softens the movement if you pop your foot off a pedal changing direction. Otherwise you'd have to hang on tight!
G/luck
Joel
   / Foward/Reverse hydro help #4
G/luck
Joel
MISC BASKET OF HYDRAULIC PARTS (A53843)
MISC BASKET OF...
2015 Chevrolet Express 4500 Shuttle Bus (A53422)
2015 Chevrolet...
2016 Ford F350 - Butler Bale Bed - 4WD - 125k Miles (A53473)
2016 Ford F350 -...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
JMR stump/trenching bucket (A53421)
JMR...
