four wires from trailer brake assembly
   / four wires from trailer brake assembly #1
rus_geek
Poniatowski, WI
Bobcat CT225
I'm re-running wires to the brakes on my (homemade, not by me) trailer and found four wires at each hub instead of the usual two. There are two heavy wires that I assume are the magnet, but there is another pair of light (20 or 22) wires coming from a different hole on the assembly. :confused:
Does anyone know what these are, or do I need to dismount a hub and take a look inside?
-rus-
   / four wires from trailer brake assembly #2
or do I need to dismount a hub and take a look inside? -rus-
yes
could be they ran the running lights etc into there as a junction location.... could be the brakes were innitally run with lite gauge wire and someone later upgraded to heavy wire knowing that the lite wire was insufficent, and then didnt pull it out....
point is... who knows...
   / four wires from trailer brake assembly #3
If I had to guess it might be the battery backup circuit for the brakes. No way to know for sure without looking or checking continuity. Have Fun!
   / four wires from trailer brake assembly #4
Not normal. Pull a wheel & drum and find out!
   / four wires from trailer brake assembly #5
i agree.. should just be 2 wires in. does no good to guess at this point..
   / four wires from trailer brake assembly #6
Never seen that one. Pull the hubs and have a look.
Chris
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
KAWASAKI MULE 500 GAS UTV (A51247)
KAWASAKI MULE 500...
HOMEMADE 82"X18' DOUBLE AXLE CAR HAULER TRAILER (A51247)
HOMEMADE 82"X18'...
UNUSED RAYTREE RMLL60-60" POWER RAKE LAND LEVELER (A51248)
UNUSED RAYTREE...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
