Four wheel drive??
   / Four wheel drive?? #1
Farmerjohn
South Central Texas
I'm about to buy a Kubota 6800m and am leaning toward a four-wheel drive. What I'd like to know is if anybody sees disadvantages to the 4 wheel drive as opposed to the two wheel: safety? other? thanks very much!
   / Four wheel drive?? #2
Farmerjohn,
I don't have a farm but I do use my tractor for many chores. The only disadvantage that I have found for my FWD is that when tightly turning, the front wheels can scar the lawn.
Next, let me tell you I don't know why one would not have FWD. I have gotten stuck many times without being in FWD, only to be resucued after turning on FWD.
Buck
   / Four wheel drive?? #3
I would not buy a tractor without 4wd. If my tractor even thinks about getting stuck into 4wd it goes and out I come. I can't even count how many time I would have been stuck with just a 2wd tractor. I would rather have it and not need it then need it and not have it.
Have A great weekend.
Jim
   / Four wheel drive?? #4
Farmerjohn,
FWD is the only way to go. I can’t count the number of times that I would have been stuck on the farm without it. With a 2wd in non-solid ground you will always the thought in the back of your mind about getting stuck. Many times I have had both axles dragging in the mud, if it were 2wd, I would have been stuck. Another thing, If the ground or grass is slick and you have a load or a big hog on, the front wheels will help bring the tractor around, where the 2wd would just slid them. I farm and use my tractor EVERY day and every farmer that I know that has ever bought a 4WD would never go back to 2WD again.
   / Four wheel drive?? #5
Farmerjohn,
I came very close to getting the M6800SD. It also has a locking front differential which gives you even more traction than those of us without a locking front diff.. The M6800SD is a fantastic tractor in every regard.
   / Four wheel drive?? #6
I gotta join in for empahsis. If you buy this tractor as 2WD you will kick yourself a hundred times over and wait for the day when you can do it all over again and get the 4WD. Buy the 4WD...if you can't afford it, wait and save!!!!
   / Four wheel drive?? #7
4-wheel drive (FWD) is handy, particularly with a front end loader (FEL) heavily filled with whatever. I've FWD, but only use it when the FEL is into a dirt pile big time, and my rear wheels are "light" as a consequence, or when it's real muddy. FWD will tear up a wet lawn if you make a tight turn, but so will locking one rear wheel (boy, that make the tractor "turn on a dime", but sure will tear up the ground under the locked up wheel). The Kubotas, and most other tractors, let you stomp down (right foot on Kubota; dumb location as it is a real hassle if you are using the foot throttle) on a lever that locks up both rear wheels - such will get you out of most heavy mud and the like (I trust you are considering R-1 or R-4 tires, with "turf tires" forget about difficult traction situations, FWD or not). That said, I've managed, as most nut case tractor drivers, gotten into situations when locking the rear differential and FWD didn't quite suffice, and I needed the FEL to help me inch (literally) out of the muck. The option was walking over to a neighbor and asking for help (not a macho thing to do). So, FWD if you're doing more than mowing a pasture.
   / Four wheel drive?? #8
Kubota M6800 4wd Utility Tractor
68 Engine Horsepower 4 cyl. diesel - 62 PTO HP
Single remote valve, Ind. PTO
Rear work light, Foldable ROPS
Syncro-Shuttle (Lo-Rev)
One Only @ $21,000.00
TractorSmart.com 423-928-0261 email sales@tractorsmart.com
Modern Equipment Co., Inc. 3003 West Market St., Johnson City, TN 37604
__________________________
Only disadvantage of MFWD is cost of about $3500. more than 2WD... but spread out over the life of the tractor is minuscule...only mere pennies a day.
I agree with Jerry... you'll never go back to 2WD after you have MFWD.
With MFWD engaged you also increase your tractor pulling power another 15-20%... it's almost like getting a larger diesel engine installed with more grunt HP... extremely effective with most ground engaging equipment like rear blades, discs, plows, boxblades, etc.
   / Four wheel drive?? #9
farmerjohn: go 4wd!!!! with 2 wd once u get the weight off rear end u are in trouble, i would never consider a 2wd again.
   / Four wheel drive?? #10
I have a 2WD Ford and a FWD Kubota. FWD makes life so much less stressful. I always worried where I was driving into with 2WD, didn't know if I could back out again.
FWD is like a pocket on a shirt you can just do so much more with it. It's not how did I do with out it but, why.
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
377811 (A48836)
377811 (A48836)
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2017 KUBOTA SVL75-2 SKID STEER (A52705)
2017 KUBOTA...
2008 BMW 535xi AWD Sedan (A53424)
2008 BMW 535xi AWD...
R-134A Manifold Gauge and Hose Set (A55218)
R-134A Manifold...
