czechsonofagun
Elite Member
I am finishing my work on Monday, washing my hands outside the house under this no freeze spicket sticking out of the crawl space. Than i took a little ip of the water and that sorry SOB feels tinkly on my lips. I tried it second time and same thing.
Got my multimeter and sure enough - 1.98V AC between the ground and the spicket - 60Hz.
I get in the crawl space with the meter - it is 3+ V on the water pump and all the pipes around. Next step I done the obvious - turn off the braker for the pump, than the braker for electrical outlet in the crawl space and so on till I run out of time. There was no change - always over 3 Volts. I will try it from the other end next time - turn of the whole house and bring it up one circuit at a time.
Now the question:
- does it make sense to ground those pipes as a temporary solution? It is an old house and it could take a while to find the problem.
Now the question:
