Found this one-bottom plow today...tell me about it...
   / Found this one-bottom plow today...tell me about it... #1
Beavonrhebayou
DeRidder, Louisiana
1963 Ford 2000
All,
I came across this one bottom plow this morning on my travels. I can't tell what brand it is as the stickers are worn off. It does have a depth wheel on the backside of the moldboard that is hard to see.
Any ideas or suggestions? I'd like to put it to work preparing some new garden beds.
   / Found this one-bottom plow today...tell me about it... #2
Wonder how it attaches to the tractor? The hitch linkage is certainly not the standard. I wonder if it was made for a specific tractor. Obviously it is very light duty, made to be pulled by something small and over ground fairly soft and previously worked. But guess you knew that already. Maybe someone else recognizes it.
   / Found this one-bottom plow today...tell me about it... #3
the lift arm pins are all that I see missing. Should do a fine job on a garden .
I picked up some lift arm pins at TSC. I'm hoping to get them on tonight and try a bit of work in a new garden spot.
   / Found this one-bottom plow today...tell me about it... #5
Setting up a moldboard plow is an art. Google "moldboard plow" or go to Everything Attachment. I think Peanut and the gang have a video on setup and operation of moldboard plows.
   / Found this one-bottom plow today...tell me about it... #6
It appears to have no shear pins of trip spring protection. So go easy, watch for roots and rocks, and be ready to use the clutch. I had a heavier old Ford plow and bent the frame and broke grade 8 bolts when I hit an unseen obstruction.
Thanks for the great advice. Fortunately here in SW Louisiana, the soil is deep and loamy or deep and sandy without a rock in sight. I'll take it easy and see how it works and let y'all know.
   / Found this one-bottom plow today...tell me about it... #8
I have a plow that looks just like this. Made by brindley. It works great on my 1026r . Turns over stalks and trash well.
   / Found this one-bottom plow today...tell me about it... #9
I think the shear bolt is being hidden by molboard.With my sub compact doesn't matter. Big rock or root just stops tractor.
   / Found this one-bottom plow today...tell me about it... #10
Yep, Brinly made a lot of them. Sometimes they were rebadged with other companies names. Most of them still around are sleeve-hitch design. I had one for a while too.
2011 CIRCLE M 32 FOOT GOOSENECK (A53843)
2011 CIRCLE M 32...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2019 MACK P164T WINCH TRUCK (A53843)
2019 MACK P164T...
2014 Dodge Charger Sedan (A51694)
2014 Dodge Charger...
2010 Ford Fusion Sedan (A51694)
2010 Ford Fusion...
