Found my 4wd problem. Now how do I fix?
   / Found my 4wd problem. Now how do I fix? #1
scesnick
Veteran Member
Garrett County Md. ( Western Md.)
Kubota MX5100
My 4wd on my 2000bd went on the fritz so I look the advice of Mark777 and checked the drive shaft and sure enough it is disconnected in the front where it does into the front diff.I did'nt look real close I had my baby daughter in my arms but it is totally disconnected, just laying there. I did see alot of oil so I'm guessing at the least a few seals will be needed. I do not have a manual ( yet) I was wondering if anyone knows of a site that can show me the diagram of parts in that area? or just explain what that area intails if possible. Thnaks a million.
I guess I should be ordering the manual soon. Then I wouldn't be buggin' you guys.
   / Found my 4wd problem. Now how do I fix? #2
My JDs (Yanmars) use a roll pin to hold the front U-joint of the
drive shaft to the front axle input shaft. If you did not have an
oil spill, I would have guessed the roll pin failed. But the oil spill
indicates a larger problem, like a cracked axle casting. Of course,
the roll pin could have failed and the the wobbling U-joint could have
beat the **** out of the input shaft, causing the seal to leak. My
drive shaft has a plastic tube that covers it and would keep it in
place for a whille if the U-joint failed.
   / Found my 4wd problem. Now how do I fix? #3
Check hoyetractor.com. They have some parts pages out of manuals to order from. You might be able to see what you need there.
dfkrug,
Just by quickly looking at the problem i would say that my axle casting is o.k. hopefully. I would think that the seal is probably beat to death.
It seems as if all I would have to do is pull back on the driveshaft, since it has a spring, and put the driveshaft back on the input shaft. But i need a diagram to see what all is in there and what went south on me.
i really don't need my tractor for a few weeks so I guess I will be ordering the manual real soon.
thnaks for the info...
   / Found my 4wd problem. Now how do I fix? #5
If your driveshaft has a spring, it is different from mine. Mine
is completely encased in 2 plastic tubes with a hose clamp keeping
them in position. This tube protects the shaft and makes the
owner overlook the zerks on the 2 U-joints. I just had mine out
to replace the front axle pivot shaft and bushings. It is very hard
to get grease in there.... Shot after only 750 hrs.
2007 MACK CXN TANDEM AXLE DAY CAB (A53426)
2007 MACK CXN...
2008 Jeep Wrangler Unlimited X SUV (A53117)
2008 Jeep Wrangler...
Mahindra MPOWER 85P 4WD Tractor (A53117)
Mahindra MPOWER...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
2017 Case SV185 Compact Wheel Loader Skid Steer (A51691)
2017 Case SV185...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
