found a 7" x 16' steel pipe here at work
   / found a 7" x 16' steel pipe here at work #1
chucko
Veteran Member
Polk Co , Fl
bx1800
found a 7\" x 16\' steel pipe here at work
it is faily new little to no rust with what looks like 1/4 inch walls on it.
it will soon become mine..
Now what should I build with their pipe for me
   / found a 7" x 16' steel pipe here at work #3
Re: found a 7\" x 16\' steel pipe here at work
Carry it home in your lunch box, then make a series of rollers out of it, like lawn rollers, aerators, etc.
   / found a 7" x 16' steel pipe here at work #4
It's a little big (7") but lay it across the rafters in your shop then hook a chain hoist to it.
Make a cannon for shooting balls, small pumpkins.. /forums/images/graemlins/grin.gif
I was thinking the same thing. No need sneek it out. They only one that knew it was here is gone and as soo as someone else finds it it would go in the scrap box
   / found a 7" x 16' steel pipe here at work #6
Cut 5' off and use that as a lawn striper.
Cut 4' off and weld some spikes on it, fill it with cement, make some removable brackets to pull it UNDER your box blade (scarifier teeth UP please) and use that as an lawn airator. (the box blade will add the weight you need to sink the teeth)
Using the same 4' piece above, make some more removable brackets for the back of the box blade and pull it behind the box blade as a soil pulverizer.
Sink the remaining pipe partly into the ground, fill it with concrete, set your mailbox on top of it, and see if the local knucklehead teenagers can knock it down when they drive around running over rural mailboxes.
   / found a 7" x 16' steel pipe here at work #7
Here's an idea: Put it in a couple feet thick slab of concrete in the middle of your shop floor, standing upright, and make it the pole for a real nice jib hoist setup.
   / found a 7" x 16' steel pipe here at work #8
Cut off a 4 foot section, fill it with concrete and make a front end weight/bumper for your tractor.
TBAR
   / found a 7" x 16' steel pipe here at work #9
Put champagne bottle bottoms in each end and use it to look at the stars.
There was a thread here once about wind chimes. a piece of pipe like this would work great, cut to different lengths, presto
   / found a 7" x 16' steel pipe here at work #10
The way steel keeps going to China....ya may want to put it into a museum /forums/images/graemlins/frown.gif
2014 Landoll VT-Plus (A52349)
2014 Landoll...
2002 FREIGHTLINER FL80 FUEL TRANSPORTATION TRUCK (A52472)
2002 FREIGHTLINER...
2015 Ford F-550 Auto Crane 4004EH 4,000LB Crane Service Truck (A51692)
2015 Ford F-550...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
