Foton254: How to separate Rear lift cylinder sleeve from the cylinder head?
   / Foton254: How to separate Rear lift cylinder sleeve from the cylinder head? #1
D0TC0M
NB, Canada
Foton TE254A
I had a leak around the flange that controls the down speed of the rear hydraulic lift under the seat. In the manual they call this the cylinder head assembly. When the cylinder head assembly comes off the cylinder sleeve and piston came with it. I took the retainer ring off the outer cylinder sleeve and removed the o-ring. I used compressed air to pop out the piston and now I wanted to remove the cylinder sleeve to change the inner o-ring but I can't seem to be able to separate the cylinder sleeve from the cylinder head assembly. It moves but won't pull out. What is the trick to separate the cylinder sleeve? Am I not pulling hard enough I don't want to frig anything up.
Ok forget it I wasn't pulling hard enough. I got it off but it was stuck on pretty hard.
(3) STEEL CARTS W/ WHEELS (A51248)
(3) STEEL CARTS W/...
2020 Terex RL4 Towable Light Tower (A51691)
2020 Terex RL4...
JOHN DEERE 661R LOT IDENTIFIER 97 (A53084)
JOHN DEERE 661R...
PACCAR PA56 WINCH (A51247)
PACCAR PA56 WINCH...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
2015 Ford Escape SUV (A51694)
2015 Ford Escape...
